what do i need to do to eliminate the need to recirculate my blow off valve?
burnout 180
Car: 1990 s13 180sx ca18det
c-rad
Car: 1991 Nissan 240SX w/CA18DET
burnout 180 wrote:what do i need to do to eliminate the need to recirculate my blow off valve?
A standalone that uses a MAP sensor instead of a MAF, or some crafty plumbing by using the MAF in a blow-through setup after the mounting position of the BOV.
Pencil Shavings
the MAF isnt bothered by boost at all? isnt it ment to read flow at atmospheric pressure?
c-rad
Pencil Shavings wrote:the MAF isnt bothered by boost at all? isnt it ment to read flow at atmospheric pressure?
Has nothing to do with pressure...all about flow. Lots of people do it. Thing is, when you start to run 20+ psi they have a tendency to explode. My friend just exploded his on his SR running 22psi.
boost_boy
Either a VPC, a computer system that's map based, or just deal with the effects of venting Atmospherically on a MAF-based system.
Dee
burnout 180
thanks for the help
float_6969
Pickles. Pickles and Beer. That fixes everything...
em55ery
Car: 91 nissan 240sx
or an hks ssqv from what ive heard
vis213
i run atmospheric bov and have no problems at all
AmoebAssassin
Car: 1991 Base fastback 5spd, black
You dont even need a standalone that's on a MAP system. Any standalone with decelleration compensation will do fine. It leans out your mixture automatically when you get off the gas faster than a set speed so as to avoid that extra boatload of fuel dumped into your cylinders after a blowoff.
c-rad
AmoebAssassin wrote:You dont even need a standalone that's on a MAP system. Any standalone with decelleration compensation will do fine. It leans out your mixture automatically when you get off the gas faster than a set speed so as to avoid that extra boatload of fuel dumped into your cylinders after a blowoff.
In that case you don't even need that. Get a SAFC and use the Dec Air function...
mikehutch711
c-rad wrote:In that case you don't even need that. Get a SAFC and use the Dec Air function...
that function is useless. I spent alot of time trying to work it, didnt do much of anything.
Just make sure ur bov is nice and tight and doesnt blow off below say 5psi.
NeedCAforS13
Car: CA swapped S13 coupe
I use an HKS ssqv and don't have any problems with the car dying or running crappy with an open BOV.
slownslurious
I have an older HKS valve and while not the most responsive it defintely doesn't cause my any problems...
F3600
I have a older HKs too its the super sound,i think. It doesnt open up when im not driving hard .. i got some compressor surge but .. i like that. Im on the side of people who think compressor surge isnt as bad as everyone think.
when i used to run a dsm blowoff, at idle air was getting out .. at every stop it was a struggling to keep the car running
