What do I need TO buy???
240sxGT_R
Car: 1989 nissan 240sx Hatchback
OK so please help me out here what do i need to build a mean Ka24et or should i go dual over head cam Because as OF right now i got a blown single over head cam what should i do help grateful thanks TOM
kouki_hmongster
Car: Want 97 kouki
Search, this have been covered.
IMO i like the DOHC better. it looks nicer, it's a newer motor, more parts in the market for the DOHC. i heard the SOHC have lower compression so that means its better when it comes to boosting, but still like the DOHC better regardless. both motor have a lot of torque so its all up to you.
For you situation go w/ sr.......Not!. you can either build up the motor w/ racing rod, piston etc.... or get a running DOHC and have fun.
To make it short get DOHC................
s14derrick
Car: 1995 nissan 240sx
actually the single cam has higher compression.
neverlift
no the teh eff bomb!!!1!!!eleven!! it doesnt.....
sohc was either 8.6:1 OR 9.1:1 depending on year
imho the sohc is a great base for boost, however not many have pushed as hard on it vs the de. nissanfanatic made 534 on stock ish with 11mm studs.
I'd go for a dohc just like I did, I had a blown sohc that I had been TRYING to find second hand parts for a budget turbo build(NO LUCK). SO a decent deal on a dual cam came along, I bought it and went t25 for under 300 bux, so 700 ish for a solid *** motor and boost
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
Why the emphasis on TO in the title? wouldn't it be better to emphasize NEED?
my .02
My SOHC made 280HP and lots of torque with a straight T3
