what do i gap spark plug to for my ka-t???
nismo_power
Car: 91 240sx fastback se
i just got some ngk iridiums bkr7eIx and was wondering what i should gap them too???im not even sure if i can gap iridium plug but im just checking...thanks
kouki_hmongster
Car: Want 97 kouki
they should be pregapped to 38 for bkr7e, so that should be a good start. Yes, you can gapp iridium just really fragile so take it easy.
480sx
Car: 1996 Pearl White 240sx
You want to spend the time and 'tune' your spark plugs. Basically, you want the biggest gap possible without spark blowout. Every motor is different. Different strength electrical system, wires, battery, levels of boost, ect.
Ken Park
Car: 1991 240SX
kouki_hmongster wrote:they should be pregapped to 38 for bkr7e, so that should be a good start. Yes, you can gapp iridium just really fragile so take it easy.
The man has Iridium plugs. DO NOT TRY TO GAP THEM. Leave them where they are, trust me. You will break the Iridium tip off. They are not meant to be gapped. Of course, it can be done, but you are gamb|ing with wasting an expensive plug. I did not know this the first time I used some and ruined two of mine. On a side note, .038" is never a good start for a turbo motor. .028" would be much more ideal. Then go up in .001" increments until you find the blow out threshold.
lrb_2000
Car: '91 Nissan KA-T hatch
I've ran my Iridiums at .038 forever. I'm running 15psi and there's no blowout.
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
lrb_2000 wrote:I've ran my Iridiums at .038 forever. I'm running 15psi and there's no blowout.
good ignition! stock coil? hotwire mod?
I hear .030 is good for 10-12psi, and a tighter gap as you up the boost
lrb_2000
Damn.. I just have a blaster ss coil, and magnacore 8.5mm wires... My car ran way worse when I lowered the gap to .030.. espeically out of boost..
NateDogg
You are using the wrong type of gapping tool if you are prying the electrode off the tip. Use one that pulls the electrode back without touching the tip.
