what do i do with these vacume lines?
AN89HATCH
On the stock intake there is 3 lines going to it, I know the one from the valve cover goes back to the intake on the turbo, but what about the other 2 that are on the stock intake? there is like one big tube, and tehre is a smaller turbe rite next to it. Do i just route these back into the cold pipe? also when taking out the smog devise on the driver side wheel well, what am i suppost to do with those 2 vacume lines? thanks
andrave
Car: 1989 Nissan 240SX Coupe
all you need is iacv, fpr, and brake booster, and if turboed then wastegate/bov.
There are only 3 vaccuum ports on the intake manifold. one goes directly to the brake booster. It is easily located. Another is smaller and on the inside by the throttle body, an ideal candidate for the fpr. And the is towards the back, a larger one, that you could ust for wastegates. The iacv you don't need to do anything with but run a line from where the hard pipe comes up by the TB into your charge piping.
mys13240
Car: 1990 240sx hatchback(for sale) 1989 240sx hatchback (KAT PRoject)
can you tell me what iacv is and where it is? thanks.
AN89HATCH
mys13240 wrote:can you tell me what iacv is and where it is? thanks.
I also would like to know this :confused: is one of the tubes that go to the stock intake an iacv line?
AN89HATCH
andrave wrote:all you need is iacv, fpr, and brake booster, and if turboed then wastegate/bov.
i believe the iacv is the bigger one of the 2, some one please correct me i im wrong
huguetpj
Car: 93 KAT Coupe
Yes... the Idle Air Control Valve(s) is the big tube next to the TB.
Structure240sx
now what about removing that black can in the front driver side? isnt there lines coming off of it going somewhere else other than the intake mani? i would love to get rid of this to make some room to move my intake up there
AN89HATCH
does it matter if the iacv is routed back into the cold pipe or hot pipe? which one do you guys rout your iacv?
andrave
Iacv should be routed to your charge piping. usually done so right before the throttle body.
the black can is your carbon canister. You can chuck it but some people say it brings a slight smell of gas. the carbon canister uses engine vaccuum to draw vapors out of the fuel tank to let it breathe, and then filters them through carbon and I believe pulls them into the intake stream. its not necessary.
huguetpj
Car: 93 KAT Coupe
andrave wrote:Iacv should be routed to your charge piping. usually done so right before the throttle body.
andrave is right, most people have it routed to their charge pipe... I know I have.
Quote » now what about removing that black can in the front driver side? isnt there lines coming off of it going somewhere else other than the intake mani? i would love to get rid of this to make some room to move my intake up there [/quote]
As andrave already replied, the carbon canister is what the engine uses to burn off fuel gases coming from the tank. If I remember correctly it should have 3 hoses. 2 of them are vacuum sources, the third one is the one coming from the fuel tank.
