brianw »
https://forums.nicoclub.com/brianw-u65970.html
Thu Jun 21, 2007 3:14 pm
4th gen I30ts have VLSD. That's the only A32-chassis vehicle in the USA to get the RS5F50V transmission and not the RS5F50A.
The transmissions are identical internally except for the differential; because of this you'll need to swap over both half-shafts and the transmission if you want to switch between the open differential and the VLSD. They are interchangable if if you do the half-shafts.
The 5hp difference between the 00-01 models is mostly a paper difference, although 5hp is small enough to be almost within tolerance on a chassis dyno. I personally have worked on both `00 Maximas, `01 Maxima AE's with 227hp, and `00 I30's, and if the exhaust is different, it must be very subtle differences to the naked eye... :p
