what differential does the 03 350z have r200v?
Nissan 350z / Nissan 370z general community discussion forum
crxcess
Car: 93 240sx fastback
Is it a r200v or r230v?
crxcess
n/m I found it....
PalmerWMD
Car: 2004 350Z
Wich diff is it?
I am kinda curious myself.
Fred...
crxcess
according to the nissan site i found, its a direct replacment for a 240sx r200v.
Nismo_Freak
Car: 89 Nissan 240SX
It's an R210.
240sxrb25det
Car: 240 with a 2jz in it
does anyone know if the 350z differential is the same as the 05 and newer pathfinder diff?? i know they have the same gear ratio 3.357 in some models just curios i would like to put a limited slip in my pathy
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I am pretty sure the path uses a larger ring gear,a nd the 350Z is reported to be the ever so common R200 which has been in Z's since the 70's
240sxrb25det
they look so similar though...the housings i mean and htey have the same ratio
evildky
06 Nissan 350Z GT
I honestly have no idea what diff is in the pathy, might want to ask around in the pathy or titan areas, I found 2 OEM Nissan LSD's listed at a discount dealer for $1000-1100, you might want to contact a few of our sponsoring dealerships, looks like it's a clutch type btw, and if you were to put a viscous in you'd have to have new shafts made due to the way the shafts engage a viscous unit
or looks for a LSD equipped model at junkyards, didn't the SE's come stock with LSD? if not I'm sure it was an option on the SE and standard on the LE
also keep in mind that even if it is the same as the Z33 and even if it's got the same ratio, you're gonna want to keep your stock ring gear, ring and pinion gears should be kept together as a set, and of course you'll have to adjust for proper backlash once any swap is done
Return to “350z / 370z Discussion”
