I think you got your gears in the wrong order or something. I did the calculation and with an LS1/T56 combo with the 3.54 Q45 final drive you would redline 4th at 142 mph (6500rpm) and have a theoretical top speed of 284 mph. All of these using a 26 inch tire, i.e. 255/40R18.C3Sierra_S2000 wrote:Nice link According to that I can go 196 in 4th gear with my Q45 rear and my LS V8. I might need a bigger rear wing LOL.
Oh and to answer the original question I use the oder 3.54 gear Q45 rear end because even with my LS1 1st and 2nd were pretty much useless unless you needed to put down a smoke screen.
Same thing here. As far as highway speeds, the rpms only drop 500, but its still nice to be able to go 5 or 10 mph faster without revving too highag240 wrote:i have a j30 in mine, stock KAde. it has a 3.916 ratio, so it's a bit taller than stock. On the freeway, i have to be at 2800 rpm to go 65 mph. I feel a small loss of torque, but a locking diff is better than an open.
That's precisely why you don't want a Q45 diffy... The SR20 has different torque characteristics from a V8. Your acceleration is going to be veeeerrrry slow with a 3.69 ratio in the rear with an SR20DET.pauliedrft wrote: it should be a little stouter seeing how it was made for a 4.5 litter Thank you for your time and replies maybe this can help someone else who cant figure out what they want to use ...
Will the j30 diff. pinion gears diff. pinion shaft and side gears fit right into the 240sx diff. case? Is that all you need?SketchyRollin564 wrote:
On a n/a KA, the stock gear ratios (open diff, or 240sx vlsd) are way better, since the engine doesnt have a lot of power, but if your ka-t, you will probably like the j30 gear ratio better, and you will get more use of first gear
Right now i get more traction off the line, as both wheels get power, less wheelspin, better handling, better gas milage, and its actually nicer for DD, and i dont have to shift from 1st to 2nd so early, and i still have enough power going to the wheels to mess around and do burnouts if i want
All in all, if you dont want a j30 diff cause of the ratios, it is still WAY worth it.
The other thing you can do is swap the guts of the j30 diff into your open diff housing, and youl have a vlsd, but you will keep the stock gear ratio
Yeah but I think I want to stay with the stock Final Drive ratio.Lev_96_240sx wrote:The J30 diff will bolt right up to the S-chassis subframe. If you ask me, that's much easier than swapping the internals
Thanks, I guess the final dive ratio really isnt that much different so the easiest thing to do is just mount the whole thing in there.SketchyRollin564 wrote:
all the info you need is on that link
That was a typo on my part. I meant 5th gear. They have a horsepower calculator to determine how much power you would need to reach a given speed based on frontal area, coefficient of drag, and weight. According to that I will have more than enough with my new motor to theoretically reach 200mph. I don't plan on doing it by any means as it would be incredibly unsafe but its neat to know that it is theoretically possible.Lev_96_240sx wrote:
