No no no no no. This information is incorrect. The early long nose r200's have 10mm ring gear bolts. The later long noses and short noses use 12mm ring gear bolts.evildky wrote:to complicate things a bit the earlier carriers used 12 mm bolts to hold the ring gear onto the carrier, all later models long and short used 10mm bolts to hold the ring gear to the carrier, otherwise the carriers are all interchangable
Yeah. It's just SSOOOOOOOOOOOOOOO difficult to change the companion flange.Perrenial Badass wrote:Wait, isn't the Z32 a R240 or something like that?
To the OP, just get a differential out of any 84-86 300ZX (NA or turbo doesn't matter) if yours is busted. To the best of my knowledge, every other diff requires much more work and is not bolt in. Even the 87-89 NA ones are different, different bolt pattern for the diff on the driveshaft.
Can you be sure that it was never swapped? Did you buy the car brand new? Out of all of the Z's that I have owned, the later R200's all used the 12mm ring gear bolts. Including the short nose's. R180's used 10mm ring gear bolts, right? It just doesn't make sense that they would switch ring gear bolts to a larger size for one year (or a few) then switch back. They did it for strength.evildky wrote:nope, the 78 had 12mm ring gear bolts, and the z31's use 10mm bolts, at least the ones I have
ah your right, been a while, I had to rotate my ring gear to load the sides of the bolts when I put the 88VSLD in my 78 housing becausse the holes int he carier were larger than the ring gear bolts, for some reason i was thinking of the bolts threading into the carier and not the gearRacinjitter wrote:Can you be sure that it was never swapped? Did you buy the car brand new? Out of all of the Z's that I have owned, the later R200's all used the 12mm ring gear bolts. Including the short nose's. R180's used 10mm ring gear bolts, right? It just doesn't make sense that they would switch ring gear bolts to a larger size for one year (or a few) then switch back. They did it for strength.
My 84, 85, and 86 T's all had 10mm ring gear bolts. My 87, and both 88's have 12mm ring gear bolts. CLSD's use 12mm ring gear bolts, same as the VLSD's. Also my s13 open rear end uses 12mm ring gear bolts.
