what diff's fit?
Discussion forum for the venerable 510, and its non-US counterparts, the Datsun 1600 and Bluebird.
sclay115
onto the rear subframe of a 510? i just read someone put an r200 into an s13, does that mean you can put a diff that fits the s13 into a 510?
steve
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the s13's use a short snout R200 the usual 510 swap is the long snout R200, I know when dealing with Z's the shortsnout still bolts in but you need a longer driveshaft, I am not sure about the dime but I'd guess it's pretty much the same, and if your brave there are people that are aswapping in the R230's
81na ZX
Car: 81 280ZX, 69 Lotus Europa
If your not going really big power, a R180 or R160 (either one could be stock depending on year, engine, etc) can be bought preatty new with a facotry LSD from underneath a Subaru.
Which ever one matches the stock 510 one preatty much bolts in - unlike the new vs. old R200.
evildky
06 Nissan 350Z GT
and oh yeah you can with some mild clearancing get R200 internals into an R190 case
datsunboy
Car: Datsuns
only problem being that the R190 is an extremely rare diff.....so finding a diff in the first place would be hard.....then molesting it to fit a R200 internals?why not just get a R200?
some people dont even believe that a R190 even exists......but a R192 does......
importer
Car: Cressida & Datsun 620
Most S13s have an R200 already. Only a few early ones had the R180, so that was not much od a swap. I have an article on how to put the whole 510 rear end under a 620 PU, so if there is a will, there is a way.Be ready to do major fabrication !
jockstrapjc
what lsd would fit into a 74 260z pumpkin??
81na ZX
Nismo makes one ~$700-800And its repackaged by precision gear IIRC, for cheaper
Both for R180s and early R200.
Return to “Datsun 510 / Bluebird”
