placham »
https://forums.nicoclub.com/placham-u38577.html
Fri Nov 21, 2008 5:13 pm
Stock RB20DETQ45 Viscous Limited Slip Differential aka VLSDit's almost direct bolt in into S13
You need
Q45 VLSD (think 300zx and Skyline use this exact same diff, might be some ratio difference) 300zx TT driver side axle Q45 driver side axle Q45/300zx TT rear wheel hubs.(x2) Your old drive shaft diff flange (remove Q45 flange and replace with your old one and torque the nut down, this will save you time in unnecessary drilling of new holes.) Your old rear diff cover (for S13, S14 can skip this step) Insulator bushings with washer and extra long bolts, crap that comes with Q45 diff (J30 and think S14 diff use same style and parts) new diff oil for vlsd diff's
Think the final drive ratio is like 4.3:1 or something, I wrote it down when I did mine but since forgot.
Brakes can now be upgraded to Skyline/300zx twin piston calipers, or you can run stock set-up.
Benefits 1. VLSD obviousley 2. 5-lug rear conversion3. Bigger axles (great if your putting down some serious power)4. Option to upgrade brakes to Skyline/300zx TT style.5. Take off will be affected(meaning car will be slower off of line) but higher top speed can be reached (if your into this kind of thing)
Note, not to be confused with 300zx N/A which is same as J30, Plus J30 had two different bolt patterns 6bolt and 5bolt. Think all 5bolt came with ABS sensor in nose of housing (pinion side).
Just my 2cents, hope this helps you in some way.
By the way, when I dont rev the car, it takes off just like a regular car, but when revs are raised (tire smoke, skid skid)LOL
