qsiguy »
https://forums.nicoclub.com/qsiguy-u27015.html
Tue Nov 07, 2006 1:21 pm
Do you have a good connection at your battery? Any corrosion that you might need to clean up? I got those same three lights a while back when my voltage regulator went out in my alternator. Voltage was high, not low, and I got those lights so you wouldn't notice dim lights or anything like that. Put a voltmeter on the battery or test it in your cig lighter while you are in your car. Thats what I did while I drove to the shop to get the alternator replaced and I had voltages up to 18 volts while I was driving IIRC. Not good, and you can toast electrical devices. I also overcharged my red top Optima and it burst at the seams.
Oh, and make sure you check that the other wires connected at the positive terminal are still connected. There are 2 or 3 wires tied into the positive battery terminal.
