What Did I Break? **Video To Help**
SoCal-S13
Car: 1984 Z31 50th Anniversary Edition VG30ET
i had my steering wheel locked to the left whilst flipping a b**** and just as i completed the turn (wheel still locked to the left) my right front wheel plowed into a 6" hole with water in it. i heard a loud a** clunk, as if the steering rack had just completely broke. drove away after yelling F*** that felt bad and got home 5 min later without notcing anything.
The next day i got in the car and now when i turn the wheel to the left only, it makes this noise...
my guess is i broke a ball joint? but it almost sounds like something is making contact with the brake shield thing and thats what is making that noise. like the thin metal is rubbing/flexing against something. Or is it the steering rack?
thanks
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Jack it up and start shaking your wheel around. It should be pretty obvious once you get down there.
Takumi788
Car: 1992 240sx Vert - sold
1990 240sx Hatch - sold
- Jack up the car
Grab the wheel at 9 and 3 O'clock and shake it. If that moves its a tie rod.
Grab the wheel at 12 and 6 O'clock and shake it. If that moves its a ball joint.
If your still at a loss, repeat the process while looking at the individual parts. See whats moving/loose and thats what you replace.
Good luck man. Should be an easy/cheap fix.
SoCal-S13
lol. i know how to go about diagnosing it. i was jw if anyone knew for sure cuz i dont have my car atm and i was just gonna buy parts. although when i lifted the car before the noise went away. only happens when the wheel is touching the ground
IBustV8s
Car: 1992 240sx
it could be a wheel bearing that just happened to my legacy outback. to many strip jobs.....lol
