What did I break??? (Suspension Q)
TimzSE
I have a '95 s14 that I keep *trying* to keep in good shape, I've done a bunch of maintenence recently, and now I broke somehting entirely new. :(
I hopped a curb, twice. Very hard. Now my steering is ****ed and off center adn I think the wheels are riding on edge on the right, which is the side I struck first, then rebounded into the left curb, and it feels like the car has extreme camber. What did I break? I really have zero suspension experience, but I have some mechanical knowledge (just changed my water pump). What am I going to find when I pull the wheels off tommorow? I'm low on funds and dont want to have to pay just for a diagnosis. So what should I look for? What are the parts likely to be damaged in curbing incidents and how can I tell whats bent. I have a digi cam, so I might also be able to post some pics. I'm really hoping fixing this thing again isnt going to cost me more than a hundred bucks. :(
TIA Tim
crzycav86
Car: 93 Nissan 240SX KAT
When I first got my license, I did some crazy stuff.. and smashed into a curb. It messed up a bunch of suspension members in the front and rear left side, and also messed up the steering alignment. The total cost, including the suspension and body work was around 3,000 dollars. It was a real tragedy.
Anyway, take pics, and let some of the online mechanics give you a diagnosis. Or take it to a shop that gives free estimates. It seems like your run-in with the curb wasn't nearly as bad as mine, but expect to pay a little more than a hundred bucks. Sorry to hear about your troubles. :(
navysnail
your toe is probobly off now too, so unless your gona do an alignment, you will probobly have to take it to an alignment center. you can probobly fix everything else by your self because you do have the mechanical know how.
hotshot240sx
Car: my 240sx
yup...first thinks first...check your controll arms...tie rod both inner and outter...struts...strut towers...sway bars...stabalizer bars...lots of stuff man...the rear is even worst...even more parts!!! do what you can to save yourself some money...then have the alignment shop do the rest!
marshun
check everything thats connected from the hub.
crashin like that will definitely make you spend more than 100 bucks.
what were u doin anyway?
IlIkEmYz
Car: 06 Z
i did something similar but my car jumped out of a ditch flying about 1 to 2 feet in the air.
now the Steering wheel has a lot of play in it.
What's wrong with my car.
navysnail
probobly messed up the gears were the wheel conects to the rack
Stuntman240
Car: 91 coupe
.now THAT costs dough
