LEXKYM45 wrote:Sorry about the late reply regarding dropping the pan on '06 M45 transmission. I talked to my service tech about dropping the pan on my flush/fill and he said they cant. There is only the screen to replace.
But they can do a powered flush. And, that is highly recommended every 30k miles. I just had my 60k one done, but I forgot to ask if the pan can be dropped (I believe it cannot).
LEXKYM45 wrote:I also asked him about switching over to synthetic oil on mine and he wouldn't recommend it. He said he's seen 3 M45s in the past couple years that have blown the engine using it.
Not that is something that I have difficulty believing was due to the synthetic oil! It is probably more likely that the owner bought into the "can do extended OCI with synthetic" and did not care for the engine properly.
I now have just over 60k miles on my M45 with a steady diet of Mobil 1 0W-40 and it behaves perfectly (except for the occasional carbon build-up which a can of BG-44K - about 500 miles before the oil change - takes care of).
LEXKYM45 wrote:He did say however he wasnt totally sure of the driving habits of all of the owners. He knew of one that was driven pretty hard and maxxed out his OCI with Mobil 1.
Yup.
LEXKYM45 wrote:He recommended a good dino oil with regular scheduled oil changes. The dealer here uses Valvoline product but he uses Castrol GTX. Ah, the debate goes on.
Like I have always said, if you do regular 3750 miles (or lower) OCI as well as the filter, then any good dino oil will do perfectly fine! If you want to use the good stuff, then go for Chevron Supreme 5W-30 or Castrol GTX 5W-30 and you will be perfectly fine.
If you want to use synthetic and like a particular brand or formulation, then please do so without fear of problems. For example, I use Mobil 1 0W-40 and like it a lot.
If you want to use a blend (to get the best of both worlds), toss in 3 qts of Castrol GTX 5W-30 and 3 qts of Mobil 1 0W-40 and it will still be just fine!
However, and this is the important point, I still do an oil and filter change every 3750 miles without fail. That is the key element to the story.
Z
