What degree range should the coolant be at ???
Jn1306
Car: 1990 Nissan 300zx n/a
I've looked all over and I can't find it... I heard its from 195 to 210 degrees Fahrenheit. Thanks guys
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
The thermostat opens at 170F. As for a typical temperature for your vehicle, I can't answer that question.
300ZXttZMAN
Moved to Z32 tech.
Jn1306
K thanks ... I got an aftermarket temp gauge because mine is out apparently. I Checked the Voltage on the single wire going to the sensor and read 9.9 and when I would connect the wire harness back to the sensor it would read 6.4 so idk... I was just wondering where my needle should be at on the aftermarket gauge after the car is fully warmed up in farenheit degrees so I kno that my z is doing fine . Thanks for the reply
