and for instance when someone say xxxx catback exhaust, they mean the part from the muffler to the catalytic converter?DanDrath wrote:down pipes are like headers. They come off of the turbos and connect to the test pipes. Test pipes are mid pipes with no cats.
so when you get test pipe you have no catalytic converter? and does upgrading the down pipe and test pipe change the exhaust sound at all?Ace2cool wrote:Catbacks leave the stock catalytic converters, and replace the stock resonators, and the stock mufflers. Test pipes replace the catalytic converters, downpipes/headers replace the stock exhaust manifold.
i see. yeah i'm looking forward to have this guy to rebuild my z the upcoming year, and i want to do a few upgrade, i think i might add a test pipe, are there any type/brand that you might recommend?NolimitZ32 wrote:Testpipes change the sound immensely because you are removing the most restrictive part of the exhaust system. the downpipes probably don't do too much but i'm sure they make a lil bit of a difference.
okay!!Razi wrote:Pieceofsand, your car has a serious problem.Sell it to me for $500 and I'll take it off your hands.
If you experience jerking at low speeds probably worn engine mounts right?Pieceofsand wrote: Not sure how accurate I am on describing the problem, but I will try my best to come close to it. This is when my Z was still running btw. Say I'm on the road/street, I accelerate(5 speed) and the car goes, say 30mph. When I take my foot off the gas pedal, the car experience a "dive" motion, the weight of my body is being shift forward. The car feels like it loses power and dramatically slows down at a unusual level. It isn't as bad when it's at a higher rpm, when when I'm going fast. The strange part of this is, if i repeat that same process, but when the car start to feel like it's "diving" forward again, if I clutch, the car will roll smoothly. Been wanting to know what might be the problem and the cause of this, give me some input on this, thanks.
i will research about that thanks bro. is the cat delete legal in cali?Ace2cool wrote:Honestly, a test pipe is a piece of pipe. Nothing special. Make sure deleting the cats won't get you in trouble with emissions in your area. Not sure about how Michigan is on smog laws. As long as you're not getting a resonated test pipe, all of them will basically sound the same.
