pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Sun Sep 14, 2003 3:22 pm
I might be able to help you with your problem,
Ca18det have individual throttle bodies type of thing right on the intake, the are located on the intake close where it bolts on to the head, these work on vaccum, the way it works, is if you are running at low rpm, these throttles are closed , but when you push the car, the vaccum sucks a selonoid and it opens these throttles in order to get more air going into the engine. If these aren't opening, the car will bog down.
I am assuming that is your problem, taking in consideration that you have checked your timing, afm, tps...etc
Good luck,
PULSAR GTR
