What could I do with 200 dollars?
Post all your Nissan electronics, car audio and stereo questions here!
Red coupe
Car: 92 Nissan 240sx Coupe
I want to get new speakers for my car and am looking to spend about $200, Im just looking for the cleanest sound with out any amps and with out any extensive work to fit it in my 240sx. Id prefer not to have to make any kind of brakets or new holes but if it ment much better sound I guess i'd be willing. Im not looking for much, just better then the 12 year old stock system.
Rex
Car: None
Does your current (assuming stock) system use "active" speakers? If so, you might find it challenging to replace the speakers for $200, as the factory HU (active speaker set-up) has no wattage/power ouput.
If your HU has wattage/power output, then a good set of 6.5" front speakers (even with home made adapters) would be better than nearly any 4x6's you could get.
Just one guys opinion .
Red coupe
I have an old sony explode for the head unit its 50w x2, as for the active speakers, im not sure I can't see them but I havent looked behind any of the trunk lining.
Simmsled
Car: TSI GTI - E46 325i
With your sony, it would be a great idea to upgrade your front speakers to 6.5s like Rex said.
Red coupe
I was afraid youd say that, I dont have very many good tools to build something like that, but im sure I can manage. what brand of speekers should I look for?
Rex
Car: None
If you're aren't going to add an amp, I'd say look for some Pioneer or Pioneer Premier, they majke some good 2 or 3 way's that shold give you full range on a budget.
There are a few other and some will say go cheap, but I disagree .
Simmsled
my favorite budget speaker line is the Boston Acoustics Rally line. Very reasonable and sounds great!
AustinSilvia
Car: CARS, nissans sr20det ftw!
i agree... a friend of mine had some rally's and they were amazing for the price. get em on ebay... plus boston acoustics just came out with all new lines of speakers and changed things up a bit, so the older rally's can be had even cheaper no thn before. look on ebay. it is really easy to mount 6 1/2 or 5 1/4 in the front on s13 style 240's... you just have to cut the right size hole in some plexi glass or something comparable, but it's a good idea to cover them up in back somehow to protect from water and such. anyway here's a link to some 5 1/4 and i'm sure you can find the 6 1/2 or any other size if needed...http://cgi.ebay.com/ws/eBayISA...=WDVW
Red coupe
Would I need an amp for those? the sony head unit I am useing is I belive 50 wats per channel will that be enough?
AustinSilvia
you don't have to have an external amp for these or any speakers really, but a good amplifier will make them sound better and louder and all that... so let's just say you'll have room to upgrade later if you want to, and if not they will still sound good.
Red coupe
Thanks for the info, Im gonna try and get arround to some stereo shops today and check out my options and see if I can get a listen to those speakers.hopefully no more crackleing speakers soon.
PoorManQ45
Try these, they are a bit pricy, but they are top quality and should work fine without an Amplifier:http://www.woofersetc.com/prod...=3426
AustinSilvia
those sound pretty clean too... the rally's are much better, but those can be had a lot cheaper on ebay.
LaughingBull
Car: 97 240sx
72 521
77 620
74 cb550
76 cb550
I've always used pioneer, boston accoustics, and infinity. All very good companies imo.
