ok so i got this s13 motor installed with all s14 emissions stuff so basically its the same as my old motor except for block and head
now the problem is that the motor starts, but doesnt run right at all, it wants to die if you let go of gas, it stumbles and kills itself usually, sometimes recovers for a few seconds but then stumbles again.
i can keep on the gas and at about 1500 or so rpm and higher it has a rattle in the engine.. i think it sounds very similar to my old motor with rod bearing knock.
i tested compression, its right at 180 across the board, +- 1 psi
could bad timing cause this much idle stumble? i cant even time the thing cause i cant get it to idle, i tried.. the timing gun also only shot in off intervals as if it wasnt picking up the signal, not sure what to point that at, maybe its not sparking correctly but all the spark parts worked fine in my old motor just a few weeks ago
http://media.putfile.com/markoengine1
okMarko
edit:it also did this when i was trying to crank it after i finsihed compression test, then i hand cranked it a few circles and it started up just fine again... wierd ?
http://media.putfile.com/markoengine2
Modified by EstoMax at 10:06 PM 9/12/2005
