Story: I have done everything on this swap by myself cuz I have no friends.... I did my own wiring, I put the engine in the car by myself, everything.....The swap is almost done but now it just doesn't want to start. So I know I could have a problem that im just over looking. When I had the car running the it would idle really high and had a low vacuum reading... 8 InHg at idle. The CAS would also get hot after a while, so i would turn it off then it wouldnt start until it cooled down. Then my starter went out, looked everywhere for one and I could not find one. So then I opted to rebuild the one I had. Got it Back freshly rebuilt, put it on and the car did nothing. Would not even try to turn. I took it off then went to vatozone to have it tested and it spun really slow. I took it back to the place I got it rebuilt at and the guy said it works fine..... Finally found a starter I could order so I ordered it to see if the one I got rebuilt was crap. I put the new one on and it did the same thing. Nothing. Oh and Ive tried 2 batteries also. So whats really bothering me is that the car would start (when the cas was cool) prior to my starter going out and now Ive tried two rebuilt starters it doesn't want to start anymore... I never messed with the car between the time I pulled the old starter out and putting a new starter on. So I dont know what could be the problem.... Also the ecu makes a clicking noise when I try to start it then move the key to the off position.
Bad wiring?
Bad ecu?
2 bad starters?
I don't know....
Im pretty much at the point where I want to throw the car off a cliff. Ive dumped to much money on this thing it doesn't start!
Somebody please help....
Thanks, sorry for long post.
