Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Sat Jul 23, 2005 6:11 pm
CHECK YOUR HARNESS!!! The harness can be enough to set the code, and with the aging KAs in the S13 you will probably find 9 times out of 10 that you have a break in it or (especially) the sub-harness, I did some research, and apparently it happens all the time, no one seems to know why. Anyway, it is only 40 bux from the dealer for new.
