What coolant to choose? or just water?
s13gebala
Car: 99 Nissan Maxima
91 Nissan SR hatch
Car is going to be operating at around 50-100 deg f street/ track car
Is there any type of racing coolant people use?
Or should i just dump distilled water in there?
Thanks
n240sxfnatic
Water is better at cooling then antifreeze, or so ive heard. If there is not chance of cold weather you can just use distilled water. I believe like a drop of dawn in the radiator helps.
s13rb25det
Car: 92 240sx w/rb25det
if your living in chicago I would not use water at all!! unless you want to change your freeze plugs every time the weather gets cold. there is this stuff called "water wetter" it is sold at almost any auto parts store you just drop it in the radiator and your good to go. I have a cooling panel on my 91 s13 and it has helped a lot when im on the freeway.
IDRFT95S14
Car: 1995 Nissan 240sx SE
RED LINE water wetter is hella good just add a bottle and fill ur rad with water i think you'll run like 15 degrees cooler than water alonehttp://www.redlineoil.com/prod...ash=1
s13gebala
91 Nissan SR hatch
ill be buying a bottle of redline then , thanks
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
Yea, me too, looks like it might actually work.
Cone Junky
Car: S13 fastback
BMW e46 328i
'Water wetter" and distilled water is a good choice. Antifreeze/coolant has lubricants in them, so pure water would fry your water pump bearings.
ZiG
Car: 1993 240sx coupe
huh, I noticed absolutely no change whatsoever when I tried out that water wetter stuff.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Iron or aluminum block?
Aluminum (SR) and you're fine running water all day
Iron and you should mix some antifreeze in so the coolant passages don't rust up.
Shabbernigdo
if it was just 100% track car then ide use waterwetter and distilled water but since it will see the public streets ide use normal antifreeze mabey just a bit more deluted then a 50/50 mix
pj
Car: 95 s14
"water wetter" you can pick it up at a partshouse, coolant/distilled water in a 50/50 or whatever ratio suits your climate.
wow-thats-a-cool-car
Car: 1992 240sx vert track car
omg I came from other forums where people are more intelligent and this question is hysterical.
This question has many answers. Like if the weather gets below 32 degrees where you live you have to use antfreeze because you will crack your block.
But if its a track car, flush it out with distilled water then drain and then fill with distilled water and water wetter so that your block doesn't rust.
Rosco
Car: 91' SR'ed Hatch
wow-thats-a-cool-car wrote:omg I came from other forums where people are more intelligent and this question is hysterical.
So you where born with this knowledge then?? Everyone starts from somewhere, have some patience and respect.
s13gebala
91 Nissan SR hatch
**** man, i just wanted to know if theres any products to use with water..
im not going to use coolant/antifreeze because chicago gets reallllly hot in the summer
anyways i was by touge factory today so i stopped by, they dident have water wetter but they had purple ice.. so i got that.
heres how it looks http://www.royalpurple.com/radiator-additive.html
thanks for the help
pj
Car: 95 s14
lol if the question was so unintelligent, why did you bother to respond after you critisized it?who told you this information? when did you learn it? did you read it on a board? did your father or brother teach you?....wait...no one cares. the OP asked a question because he didnt know the answer, he received good answers. done deal.your not on a leash are you? then go back to the other forums that are full of smarter members and that are full of hysterics.or you could stay and realize,that nico is awesome.
shimizu_17
I use half honda coolant, half distilled water, then a bottle of purple ice.
HurryupandrunS13
Car: 1992 240 fastback
DO NOT run pure water in your car, I don't care WTF anyone has told you. Not smart....
