What connects to this?
imprecation
Car: 93 RPS13
Where does this elbow hook up to? I'm assuming thats where the stock oil cooler is connected but since I don't have one where should I route this elbow? Is everyone elses block like this?
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
I had that hose split on mine just the other day.That's a crank breather, that connected via a metal pipe and two rubber hoses to the back of the intake cam cover.
I took a photo, which is lucky for you :-)My CA18det is a later model, and has a factory Oil cooler.
Chris
imprecation
Car: 93 RPS13
Thanks man, Just to make sure we're on the same page, Is this the port that it connects to on the back of the valve cover?
dattodude
Yep..that's it
biosehnsucht
dude, fram, are you out of your mind?! Go get an OEM filter!
imprecation
Car: 93 RPS13
it's a freshly rebuilt engine, i'm gonna do what i read that float does and run it hard for the first 20 miles then change everything all out to break it in. Out of curiousity, what's bad about FRAM filters anyway?
oh yeah and thanks dattodude you've helped me out a lot.
sideways danny
Car: s13, CA18DET
nothing at all wrong with Fram filters
xyster
Car: '00 Prelude
make sure you put a quality hose with good clamps on that elbow. That thing is near impossible to change once the motor is in.
biosehnsucht
Fram are notorious for crap, look at the Fram section here for example.
also here.
This is a reputation of cheapness and poor construction they have earned over the past 15-20 years at least.. sure you might not have a problem but our OE Nissan filters are built so much better and really don't cost that much, I'll take my OE filter vs Fram or any other "aftermarket" filters any day.
I always keep one or two on hand so I don't have to make a last minute rush to Nissan to do an oil change
kapower06
^^ I second that.. Fram filters are crap. search google for oil filter test or something and you'll see that they are not good.
capwred
i dont like fram either but i dont use oem ones either.i use the k & n filter.
imprecation
Car: 93 RPS13
well i'm sold. I'll never use a fram filter again for the rest of my life.
