what company makes cam gears for ca18det?
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
wanted to upgrade from stock.i did a search and nothing came up?
c-rad
Car: 1991 Nissan 240SX w/CA18DET
splintercell wrote:wanted to upgrade from stock.i did a search and nothing came up?
Pretty sure the big names like HKS, Tomei and JUN... but good luck finding any. You best bet is to wait for a used set to pop up on ebay.
Kouks
Car: 1996 Nissan 240sx S14 Sr20det
http://www.more-japan.com definitely carries tomei for the ca. I emailed them and they gave me a list of what they had. check em out.
ragenasian
Car: AE86 w/CA18DET
JDMSIL80
Does CA respond well with cam gear tuning? How much power gains can be seen? or is it just a matter of switching the power curve?
sideways danny
Car: s13, CA18DET
tommis-billet make them. much better quality than any HKS toss
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
I've only heard of cam gears doing something for people with a shaved head and/or different cams. They are not a performance modification in their own right.
JDMSIL80 wrote:Does CA respond well with cam gear tuning? How much power gains can be seen? or is it just a matter of switching the power curve?
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
its also a good possiblity that RB cam gears will fit, they have the same amount of teeth, but i am unsure if they are the same size gear diameter wise. if they are they should work.
Smurf6x6
Car: 93 CA18 Coupe
RB cam gears do not work the sit to close to the head..
fraz
Car: rb30det gts4
vh45 g130
RB gears can be machined to fit, they are inch width and CA is 3/4 inch, just take off what you need so they are the same as your stock ca ones
splintercell
ill let the performance shop know that.i think we might just go for the tomei cam gears as long as they are in stock.thanks for the info
themadscientist
I am doubtful when it comes to the value of adjustable cam gears. unless of course the head has been shaved in which they are easier to correct the valve timing with than remachining the stockers. I just get a sick feeling about those goobers coming loose at full anger and letting my pistons and valves become aquainted
top_secret
raretrick has the JUN ones
They are $280 dollars
http://www.raretrick.com/index...=6067
81na ZX
Car: 81 280ZX, 69 Lotus Europa
Don''t tell me you guys just drop in new cams without properally installing them...
Adjustable cam gears are a neccessity to dial in cams - thus properally install them.
top_secret
they aren't necessary but they can help you get a couple extra HP.
