what colour are oem RB20 injectors?
Sir. Driftalot
mine are yellow tops is that oem?
Sir. Driftalot
here is a pic of them
Carl H
look like r32 gtr injectors to me so 440cc squiters for you.stock is red and only flow 270cc.
Eikon
Car: 71 240z, 93 Supra TT
I agree with Carl...
My stock Rb20 injectors are a dark red. I bought a set of RB26 injectors and they are yellow as pictured.
You should be careful as you install that engine.
If someone modified it, upgraded fuel to match, then maybe took back their SAFC unit or whatever they were using to control everything before dumping the car... you could get yourself into trouble if you fire it up with the wrong sort of engine management.... just a thought..
Sir. Driftalot
Yep im going to be using a power fc, I just need to figure out if these indeed are gtr.
The numbers written on them are
a46-00
7703D
Anyone care to check their GTR injectors ?
:P
Eikon
I'll do it when I get home from work.
All say A46-00 on the side
Top reads... OJ50 2310DOJ50 2309DOJ50 2309DOJ50 2309DOJ50 2310DOJ50 2309D
I doubt there's any differance between the last digits...
Modified by Eikon at 8:08 PM 2/6/2006
Sir. Driftalot
OJ55 7703D is what mine say on the tops
Eikon
Could be from a different model year?
I would guess as long as they are yellow top and have A46-00 on them, they are all the same flow...
Carl... Do you agree?
Carl H
yeah i suspect that the pn's changed but are still the same.if you are really worried take them out and send them to some one to be cleaned and tested, i believe those injectors can be highflowed as well....
Sir. Driftalot
i was at my friends shop today they have a r32 gtr in there. Injectors look identical
number was OJ50 forget second half im almost sure mine are gtr thanks folks
themadscientist
those are GTR injectors, no doubt. RB26DETT yellowRB20DET redCA18DET white (they drop in to and are 370cc)
