What clutch!!!
briguy
Car: 1995 240 sx se
I have researched this alot, and I want to know what the best clutch I should use,I am running a t25 around 8 psi,and I am undecided between a spec stage 3,Act 6 puck or a stage 3 zoom.There is so many partials threads about this but I want to know what the fellow Kat guys are using not the sr guys or the rb guys.
Florida240sx
I love my RPS clutch but that's overkill, 400ftlb
eazye2000
Car: S13 KA-DET
I'm gonna have to say RPS too..
I personally have the ACT Extreme pressure plate with a Carbon Metallic sprung disc, but it doesn't really have that much more pedal 'feel' than say a RPS stage 3 or so. It holds just fine, but the lack of pedal 'hardness' kinda makes me uneasy when I do clutch-kicks at 5k RPM's...
S13FX
Car: '69 l20b Dimeski :)
Spec 3 with their steel fly wheel. That thing is awesome, grabs like nuts and retains stock feeling ..
Brandon93240
Car: 1993 240sx
RPS all the way. You don't have to get the bad boy, the sport plate and street disc are fine for the power you have.
briguy
Car: 1995 240 sx se
ANYONE HEARD ANYTHING ABOUT ZOOM CLUTCHES,SUMMIT RACING SELLS THEM,ALSO WHERE DID YOU GUYS BUY YOUR RPS CLUTCH FROM.
Brandon93240
Car: 1993 240sx
I've ran a zoom in a stang, held good, I have no first hand experience with them in an import. Spl parts has the RPS in stock.
WDRacing
SPEC FTW, everyone else loves the c***!!!
eazye2000
Car: S13 KA-DET
Yeah, forgot about SPEC. They are decent and haven't heard anything bad about them as far as the KA goes. Enjuku Racing has them in stock, and has pretty good deals on them. And they are a sponsor.
Craving4Boost
Car: 91 240sx fastback
clutchmaster stage 5 is the best bang for the buck in my book...
ace0073
Car: 1969 datsun 510
seems that RPS is winning the major vote but personally, I just asked this same question on a thread a few months ago. I ended up going with the SPEC stage 3+ (485 ft-lbs). You may consider this overkill for your setup but if you ever upgrade....you wont regret it. if you dont ever upgrade, you still wont regret it...catch my drift? I have learned to always go with overkill (of course to an extent) because there is nothing worse then having to make purchases twice, three or four times, unless you have endless pockets! Now, back to the clutch question, I like the SPEC and my only complaint would be pedal feel......a little mushy but I may need a new master or something. Point: I would still recommend the SPEC 3+. My $.02 ....also. if you get it make SURE you get it from ENJUKU, they are the best and so are their prices.
WDRacing
I like the SPEC feel because it's so similar to stock and yet it holds the aformentioned "crap ton" of torque. SPEC FTW....
Brandon93240
Car: 1993 240sx
The spec feels alot like stock in a 240? It felt like my king cobra did when I had one in my c5. My RPS feels very nice. My friend has a centerforce in his s13 and it feels like a honda because of the weighted pp., I don't really care for that.
briguy
Car: 1995 240 sx se
Well I just bought a Spec stage 3 from Enjuku for only 300 shipped,They have great specials going on right now on the specs,If you search Enjuku on the search button you will see a post of there prices come up.Wish me luck on the spec stage 3!!!
spooled240
Car: kouki s14
What about the centerforce dual friction? I can get them on ebay for 285 shipped...what do you guys think?..
Brandon93240
Car: 1993 240sx
Its an ok clutch, phillsnotfalling has one, holds good for power under 350whp. Hes even put about 60k on it and it grabs like new.
spooled240
Car: kouki s14
Cool, I actually just purchased one on Ebay for 240 shipped. I only plan to make about 240 whp so this should be more than enough...
Spiffy240
Car: 1992 White 240sx Fastback SE
I am also in the market for a nice clutch and i agree with ace0073 if your goals are high and your expectation are high go with quality parts right off the bat.
But I am starting to lean towards the Spec Stage 3 from enjuku but my next question would be should i go with an Fidanza flywheel or go with the Spec flywheel. The prices are really close, the Spec being only 20 bucks cheaper. So, which one is better with a Spec Stage 3 clutch and can I hear some experiences with setups with different flywheels.
THANKS GUYS!!!
WDRacing
I have a Fidenza only because SPEC didn't make one when I bought the clutch assembly.
WD
Spiffy240
bump
can anyone answer my question please? i want o hear some opinions
WDRacing
Both flywheels are quality pieces man. Neither is going to yield any noticeable difference to the driver. So it's a matter of opinion and price...
I'm always a fan of buying parts made to work together, IE SPEC clutch and SPEC flywheel.
spooled240
Car: kouki s14
i think it would depend on what you want. If you want the lightest flywheel, they get the lighter one..but if they are identical in weight, then I'd suggest going with the same brands like WD mentioned. Either one, it will work fine.
