The 2001 clutch plate fits with no issues. In fact, I think if you order a new clutch plate for your 1991 car at the dealer, you'll get a 2001 clutch anyway. You can use a new 91 throwout bearing a new 91 pressure plate. I'm not sure if there are differences in the 2001 on those two.MsRae wrote:Ishkabibble - are all the 2001 parts going to be compatible with the 91?
I disagree with nametakennow's opinion about the DET, as the VE is much more reliable, your total cost of ownership will be much lower, you'll have to fiddle with it less, and you should be able to pass emissions without any problems.MsRae wrote:A swap for the SR20VE huh?
Weird, the passenger axle usually just falls out if it's not the original one.MsRae wrote:BTW - I have it up - have gotten the drivers side half shaft out, but I am having a little difficulty with the passenger side half-shaft. The dang thing seems stuck, is there a trick? or do I just need to force the dang thing out with a pry bar/screw driver? I did it a while back but I can't remember now....
Ok, thank you. I still haven't picked up the parts so that will be my plan on Monday.ishkabibble wrote:
You're looking at about $100 for the clutch disk, $100 for the pressure plate, and $30 for the throwout bearing at the dealer.
Yes, I did take off the three bolts to the carrier bracket. I was thinking exacly as you said and it should just fall out, it is usually the drivers side that is the trouble maker (especially getting it back in!). I'm also not certain of the brand that is in there so I will just have to work at it and pray for the best (hope hope hope the diff isn't hosed, but I don't think it is).ishkabibble wrote:Weird, the passenger axle usually just falls out if it's not the original one.
Did you unbolt the carrier bracket (held on by 3 bolts halfway down the axle)? The axle may be rusted in the bracket.
If you replaced the axle with a cheap rebuild rather than a new Nissan, Raxles, or GSP axle, the splines may have gotten twisted in the differential. You'll have to whack it with a big freakin rubber mallet until it comes out. And then your diff may be hosed.
I just wanted to give a quick update. Got the half shaft out and you were right on the money. It was rusted in the bracket. It finally came out (after much hammering, one broken screwdriver, and alot of cussing). Making for one very slow clutch repair....ishkabibble wrote:
Modified by ishkabibble at 7:28 PM 6/15/2008
Modified by ishkabibble at 7:29 PM 6/15/2008
Sounds like a good plan. Does the Sentra SE (I am assuming this is the same - B15) just bolt stright up or will I need to do some modifications? And will the clutch kit that I just purchased for the B13 work with the updated transmission? Sorry if I sound like an idiot, but I've only fixed things, never ventured into the swap thing.nametakennow wrote:I'd go for a used transmission to replaced the one with the bad 5th gear. Your best option is the LSD trans from a 2000-2001 Sentra SE with the performance package, as it has no 5th gear popout issues and is stronger than the B13/14 ones. The 99-01 G20 Touring has the same trans. If you don't care about the extra strength you can opt for an G20T or SE-R transmission 1995+.
Thank you so much. You and ishkabibble have been a tremendous help! I don't know how to thank you enough.nametakennow wrote:The SE's trans will bolt up just fine. The clutches are also directly swappable.
Aside from a junkyard I don't know where else you could get a transmission cheaply. Try Google, you may find a junkyard network online that runs cheaper than a local one.
If the rebuild kit is that much cheaper you may be better off just doing the rebuild, assuming that the rebuild means you won't get 5th gear pop-out again for the life of the transmission. I don't think a bit if extra transmission strength is worth the extra cost at that rate.
Yep, they are pricey. The cheapest I've seen one go for via the normal avenues is $650.MsRae wrote:I priced out a used transmission from the local transmission shop I have used. For a used transmission from a 2000 Nissan Sentra SE it was $1,500.00!!
I see them all of the time on the forums I frequent, for $150 to $400. They sell pretty quickly, though.MsRae wrote:I have not had luck finding used ones on the forums. For now I am going to rebuild unless someone chimes in that knows where a used transmission for under 400 might be.
You will gain and lose revs much faster, and the friction surface of the flywheel is replaceable. It makes your car 10lbs lighter, too.MsRae wrote:The biggest question I have at the moment is this: The Fidanza flywheel is pricing out ranging from just over $300 to over $400. To turn the flywheel would be significantly less. What are the advantages of getting the new performance aluminum flywheel over turning the one I have?
