What CD Changers plug into a 95 Q45?
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
I want to buy a OEM CD Changer to put in my 94 Q. I see them on ebay as a 10 disc sony and then there's a six disc sony. Does anyone know exactly which ones simply plug into the 94 Q45's standard harness and can be controled from the OEM in dash head unit?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
The trick is to get the correct model number with the proprietary piggy-back control unit that interfaces with the Clarion head unit.
Part No.: 28184 68U01
Model No.: CDX-5NG54G
You will need the mounting rails and the cover and clips for an OEM installation.
Rex
Car: None
Wasn't there also a Sony? Jeff W & AZ have gone through several different ones, so one of those gents should have a model number.
I went late model Nis/Inf Bose In-Dash .
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Rex wrote:Wasn't there also a Sony?
The numbers I posted were for the Sony OEM in my t model.
There was a six CD Alpine(?) that hung under the rear parcel tray that was a dealer add-on.
Rex
Car: None
My mistake, I saw "Clarion" and thought you were referring to that model. There's a Clarion 6 disc unit, that Wes loves. I'm sure he'll chime in after school .
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Clarion made the "Bose" head unit for the G50.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I swear by my clarions!!!!
I love em... Been through 2, and love em both!
maxnix wrote:There was a six CD Alpine(?) that hung under the rear parcel tray that was a dealer add-on.
Your thinking clarion, and they put it in the same place that they put the factory changer, with a special cover made for it....
Rex
Car: None
elwesso wrote:I swear by my clarions!!!!
And a part number????
elwesso
2007 BMW M Coupe
Will get when i get home, the BAD Q is at home, and I am up at the lakes dismantling my old Q....
Getting out the sawzall tomorrow
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:Your thinking clarion, and they put it in the same place that they put the factory changer, with a special cover made for it....
The only other non-OEM non-Sony players I have seen are mounted under the parcel shelf as opposed to the passenger corner of the trunk floor with the OEM brackets and cover.
elwesso
2007 BMW M Coupe
Thats odd, because I know that mine was down there and had a specific bracket for it. Also i know a couple of other members here than have the same thing.....
I guess since it was a dealer installed option, it varied..
Mark86T
Car: 96 Q45, 86 Z31T, 01 Ford Ranger, 77 280z
I have a 6 disc changer for your Q. I had it in my Q for about a month then went with an MP3 head unit.$75 + shipping
elwesso
2007 BMW M Coupe
Is that FM modulated???
Mark86T
No it isn't FM modulated. It plugs directly into the factory harness in your trunk. If you don't have the factory harness in your trunk then it also comes with the harness that plugs into your OEM head unit & runs back to your trunk. This changer works with the stereo controls of the factory Bose unit. Don't have the factory Bose head unit? I have that also. Cheap & in perfect working order. I upgraded to an MP3/CD player head unit.
AlabamaDan
1998 Infiniti QX4
Who makes that changer?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Hmmm. Not seeing the mounting rails nor brackets for the OEM trunk mount.
The rubber hangers in the OEM Sony changer are mass tuned and directional so that they suspend the unit in its case when mounted vertically. They would not work in a horizontal installation. Probably why aftermarket installations goes for the under parcel shelf mounts.
Sometimes my new Tokico blues will upset my CD player on a harsh impact.
