Booztd 3 wrote:Mechanically, the insert springs that align the syncros break/snap and fall apart into the case. With these missing, grinding is more apparent
I tore down a Z32 and an RB25 transmission here
http://www.rbz32.com/viewtopic.php?f=2&t=57
You can see what the inserts and the syncros look like after the inserts have gone missing...
FYI - I use redline 75-90 in my trans
This is 100% dead on. Happened to 2 of my RB25 trannies over time. Worn synchros and little clips coming out with fluid change. MT90 is best for trannies IMHO. Royal Purple sucks for manual trannies. MT90 will *help* worn gears, but it can't replace your worn snchros for you.
A lot of gear oil people use includes the additive for an LSD (friction modifier) and this can be very slick for synchros. Removing that friction modifier can help spin them up quicker, but again, fluid can only do so much. Also, mine didn't grind typically until I got the fluid heated up and thinned out a bit.
