BoostFab »
https://forums.nicoclub.com/boostfab-u11693.html
Mon Sep 01, 2008 11:31 am
if the boost climb to 13.7psi then settle back down to 12psi, then you are probably experiencing "boost spike". but on the other hand if your boost stay up at 13.7psi then you are experiencing "boost creep". if boost creep is the case, then your wastegate is not flowing fast enough to bypass the exhaust gas. now if boost spike occurs, either your source lines are too long or too small and it cause a delay to and from the boost controller.
