what can it be? fuel injector leak? HLEP!!!!
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
i was on my way to get the car dyno tune and i discovered a big problem. the car started boggin as if it was boost leak and then the car starts to idle really low and ends up dying. Been running this car for weeks untuned and not pushing pass 3.5krpm with no problem. until i started leaving for dyno tune and all of a sudden this happened. after letting it cool off i check my boost gauge and drove it without any problem and it ran fine as if nothing happen ANd until i ran it for a couple min then the same thing happened again. boggs at certain rpm and then it dies. i used the scanner on it and it threw out code 45( Injector fuel leak) and EGR which is normal.
i checked for boost leak and i cant seem to find any leaks. also checked for vacuum leaks and the vac gauge reads 19-20. weird because the car idles fine after it cools down and boost fine.
what can it be?
91 KA24De-srT25(redtop)running 270cc injectors. have 450cc not installed(d-werks)stock MAFwalbro 255lphz32 fuel filterAFC neo (not installed)greddy type-M FMICHKS hotpipe ssqv combophase2 nobrand turbo maniblitz3'' d/pmegan elbowdelete cat w/buddyclub spec2 exhaust
thanks!
240sxvaj
oh yea almost forgot whenever its about to die i gas the car my rpm wouldnt go up.it will just drop down until i let off the gas and then it idles (back to normal) ok when im not in gear
Florida240sx
Check the spark plugs? What kind you have in her? Got an aftermarket FPR? Check the vaccum line to it whether stock or aftermarket...?
240sxvaj
spark plugs are NGK irdium plugs and stock FPR.vaccum lines stock?
i was doing some research on it and some guy had the same problem
someguy said it could be his crankshaft sensor, because it will over heat when it reaches it normal temp. so when its gets hot the crankshaft will send wrong info to the computer so the timing is thrown off
how long will that thing take to replace?and if i set my timing back to 20 will it stop the over heating?
Modified by 240sxvaj at 12:29 AM 12/21/2007
Florida240sx
Your car is overheating? Might be a blown HG...CAS is inside the distributor on s13 so oyu need a new distributor. Run your ecu for codes see what comes up.
240sxvaj
Florida240sx wrote:Your car is overheating? Might be a blown HG...CAS is inside the distributor on s13 so oyu need a new distributor. Run your ecu for codes see what comes up.
my car isnt overheating. it runs fine on its normal temp.
but then im thinking the crankshaft sensor is going out. correct?
my timing is set on 15 and im thinking the crankshaft sensor is over heating cause it sends wrong info to my comp and then it causes the timing to be thrown off. can that be it?
so if i was to set the timing back to 20 will the crankshaft sensor stop over heating?
because before i set the timing it was on stock timing and it ran fine without over heating
the ecu codes came out to be the: injector fuel leak, MAF, Idle switch (throttle valve switch) signal circuit open, and EGR but then that egr code is gone since i block it off.
i got it tested at the shop
on the injector leak i smell or see no gas leak on the fuel railand the maf i know is ok because i never had any problem with itbut then then idle switch i woulndt know
Modified by 240sxvaj at 12:59 AM 12/21/2007
480sx
Car: 1996 Pearl White 240sx
Im really curious as to whats making the ecu throw a code for leaky injector. I mean what kind of information are the obd1 sensors is giving the ecu that would possibly let it know that the injectors are leaking, pretty wild imo. Maybe an excessive rich condition across the board for your narrowband o2 sensor? Idk, just a stab in the dark.
I would try to follow that lead first. You should take your fuel rail off, prime your fuel pump with a piece of paper towel or whatever underneath your rail and see if you get any drips when you run your fuel pump a few times.
240sxvaj
i think its my coolant temp. sensor
i kept it plug in and then drove til it gets hot and when its about to die i unplug it and drove it. and it didnt really stall asmuch as it did when it was plug in.
so now im gonna replace the sensor and see if it still does that
emo_tactical9
240sxvaj wrote:on the injector leak i smell or see no gas leak on the fuel rail
Correct me if i'm wrong, but for "injector leak" it means it's leaking into the cylinder, not out the fuel rail, right?
240sxvaj
im not too sure but from what i heard when the o-rings are mess up gas comes out to your fuel rail. correct????
coolbone28
Most of the time it will leak into the cylinder. You have to take out the few screws that hold down the actual fuel rail. Pull the rail off and the tips of the injectors will be exposed. Turn the key to the ON position so the fuel pump primes. Check for drips/leaks.
240sxvaj
as of rite now im in the process of replaceing my stock injectors with my 450cc.
so i'll keep you guys updated of the aftermath
Florida240sx
Replaced your cts as well?
240sxvaj
Florida240sx wrote:Replaced your cts as well?
just installed a Brand New Coolant Temp. Sensor and it ran a bit better, but still showing the same symptoms
tmorgan4
Car: 2000 Nissan Pathfinder
Did you ever figure this one out? I've got the exact same code and symptoms on my VH45.
240sxvaj
tmorgan4 wrote:Did you ever figure this one out? I've got the exact same code and symptoms on my VH45.
injectors wasnt good.i change them to my 450cc and it ran fine after that
