What can I get beforehand?
Oneor1
Car: cars, music, hockey
Hey guys whats up? Need some suggestions on what you think will be needed for a Ca18det swap..... Hopefully I'll get the engine, transmission,ecu & harneess as well as a SMIC all together..... What my question is, is what all can I order and stock up on for parts that i'll need for the swap. such as maybe BOV, elec. fan, Fuel pump, Downpipe (what kind?)...etc... things like that
any help/suggestions are appreciated varily
thanks,Rick:pface
nomore_mr2
order a hks metal headgasket new head studs new timing belt water pump oil pump entire engine gasket kit. take your oil pan off adn check the bearings. replace if nessicary. get a new clutch and resurface teh flywheel. since thats off replace the rear main seal. then redo your oil pan gasket. if your going for power order cams and valve springs since the heads off. also order a new fuel pump. then buy bolt ons. intake exhaust and downpipe. dont put a intake before any engine work make sure the engine is in prestine condition.
Oneor1
If i were to go to autozone, napa or some place like that, what motor would I used to refer the parts such as timing belt, head studs, oil pump...etc.... i believe its somthing like a 80 something pulsar w/ a ca18de but not sure.....any help with that?
-Rick
Bryson
Car: 93 240sx Hatchback /w Sr20
I believe its an 88 PulsarNX and ya it does have the CA18DE.I believe Moving Violation posted something once in the general forum about parts that were interchangable, I think it was practically all maintenance parts otehr than pistons, but don't take my word for it without checking.
