WestTxSR20Tuner wrote:Well my Megan racing tubular mani is causing my coupling to melt and creating boost leaks. I have tried moving the turbo over, heat wrap, heat tape but sooner or later it melts. In Megan Racing's defense it wasn't there product that failed it was the alignment shop not looking out for my exhuast when the lifted it up. I'm thinking about just using my log manifold.
What can exspect in power lose if any? I run at 13 psi and I have Tomei 272 degree cams with 3" outlet pipe and 3" exhuast.
Maybe I am just blanking right now, but what coupling are you talking about? The only couplings I can think of around that area are for the hotpipe, and even then it doesn't really make sense that you could melt that one.
Also, 272s on a t25 is hilarious unless you plan to run a bigger turbo in the future.
