I have a 89 r32 gtst rb20det (motor originally from a r32 gts4)
i'm wondering what sort of power ill be looking at with my build (first build i have done)
right so its a rb20det with a t3t4 low mount turbo with a custom built 3 inch exhaust, straight from the back of the turbo, look off the old 2.5 inch dump pipe, leading to 1 muffler and a short twin boso.
Red Jacket coils (similar to spit fires)
external waste gate with 1.0 bar spring
440cc injectors with factory fuel rail and a walbro 500hp fuel pump
front facing plenum with the factory throttle body with a large front mount and 3 inch pipes.
z32 air flow meter
288 kelford cams cam shaft and hks cam gears and cam belt
factory drive shaft (chop and weld) with a SR20det gearbox.
i think thats about it. thanks for taking a look.
