3K is a very tight budget for this car. I am already at 5k and I have not even put the parts in the motor yet.
Option 1: Just swap the motor. Under $1000-$2k cost DIY
- In this option you want to keep the motor intact and just change all the old vacuum and coolant lines so they don't leak once the engine is in the car.
- Delete EGR. $30 kit from CZP or Z1.
- Change the Oil pump with new Nissan Genuine pump ($165-200).
- Change front main and rear seals.
- Change timing belt and water pump.
- Change clutch or go lightweight flywheel and clutch upgrade ($360-$500).
- Upgrade injectors so 370cc don't max out even though stock injectors are fine at 15psi on stock turbos.
- Pop-charger (Cold air intake).
- ECU Chip ($100) from reputable place like Z1, CZP, etc. This will let you run higher boost to safe 15psi which should put you at 350whp. People have pushed more on stock turbo. It all depends on the health of your engine and turbo.
Option 2: Around $4k-$5k Build for more power.
- Buy the CZP engine rebuild kit for $1444 as someone recommended to me. It will cover Forged Pistons, Rods, All gaskets and bearings. This will give you a good platform for over 500hp.
http://www.conceptzperformance.com/Cart ... 154.21.231
- Buy upgraded Garret turbo's for $1000-1400 with GT28r compressor side and hot side.
By this point you will have already exhausted your $3k budget.
- Don't forget machine work costs.
- Downpipes and Exhaust will run you $340-500.
- Nistune ($600) recommended.
- Other miscellaneous things.
Option 1 will give you best bang for the money and keep stock reliability. Option 2 will give you the ability to hit 400whp-500whp but it depends on a lot of things and right upgrades.
zswap0429 wrote:Im building my vert up as much as i can but i have a very low budget since i have to fix the body now at the same time as my engine swap.
What i have:
93 z32 convertible
90 z32 t-top tt (parts car)
I plan to swap the engines over the summer but i need to know what i should do while the engines are out. Like should buy a rebuild kit, new efi, etc.
Also i think one of the turbos might have a blown gasket.
So is this a possible build or am i going to have to hold up and keep saving?
