My money's on the broken motor mount... Does it make any sound when you first press the gas pedal if you take off hard?gumby74 wrote:Check your motor mounts
Go to a tire shop and have your front tires checked and your wheels balanced balanced. A warped tire will cause this problem because if you roll some thing that is uneven its very rough and bouncy. If your tires have a flat spot on them or a bulge in them this can cause the same problem as well. Like i said just have a tire shop examine both your wheels and tires and get the wheel balanced its no more than 5-10 dollars per tire and will make all the difference in the world, if its anymore find a new shop.tycoonist wrote:when i get off of the freeway(i dont go over 65. people hate me) the front end shakes like crazy. move your hand up and down about 2 inches very quickly.
alright thanks manKlits562 wrote:Go to a tire shop and have your front tires checked and your wheels balanced balanced. A warped tire will cause this problem because if you roll some thing that is uneven its very rough and bouncy. If your tires have a flat spot on them or a bulge in them this can cause the same problem as well. Like i said just have a tire shop examine both your wheels and tires and get the wheel balanced its no more than 5-10 dollars per tire and will make all the difference in the world, if its anymore find a new shop.tycoonist wrote:when i get off of the freeway(i dont go over 65. people hate me) the front end shakes like crazy. move your hand up and down about 2 inches very quickly.
