what can i do to get more power ? im only running 7psi.
91nissantwo40sx
Ok my SR20DET is stock running at 7psi, the only thing i have inside is a boost gauge. What else do you guys recomened me to have? Everything about my SR20DET engine is stock, intercooler..etc.. help guys!!
otterman
You could try upgrading... everything. Yeah I'd try that.
sbanzer123
Car: 95 s14
take the turbo off.
Tulsa_S-13
Car: 1991 SR 240sx
Are you running stock exhaust still too?
If you're on a budget you could always buy a manual boost controller and turn up the boost to 10psi.
oki_bum
Car: SR Powered 1990 240SX
If you already have the basic bolt-ons, just up the boost with a boost controller. If you want anymore power past 12psi you'd have to upgrade.
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
Full 3" exhaust form turbo back, electric fans, turn up boost to 10-12 psi (I'd not go past 10 on the stock SMIC), other than that, you'd have to spend $$ on upgrades.
91nissantwo40sx
Tulsa_S-13 wrote:Are you running stock exhaust still too?
No i am not running a stock exhaust. I have a 3" but everything on the engine is stock. So i can boost up the turbo to 10psi no problem without having to upgrade anything? will it hurt the engine even just a little bit or no? Anyways if i were to upgrade, what do you suggest i get first?
zenkizen
Car: S14 Zenki
i was boosting 7 psi when i first got my stock redtop. as soon as i switched to a 3 inch downpipe, testpipe and catback exhaust.....the boost raised to 9 psi.
i also went with a really cheap cooling route..------>stock radiator, but with a ford taurus fan. the fan cost about 20 bucks at the junkyard and there are easy write ups everywhere.
i have a hallman pro Manual boost controller from my last ka-t setup. not planing on boosting more than 12 psi.
9 on daily driving and 12 on autox days.
another cheap mod that is probably needed is a 255 walboro fuel pump. 50 bucks
oh and a ebay FMIC for boosts over 10 like everyone else says
otterman
91nissantwo40sx wrote:Anyways if i were to upgrade, what do you suggest i get first?
hi-press fuel pump if you dont have one already (I heard its really bad to run without one, I Dont know from experience though) then go drivetrain or cooling starting out.
xdabsx
Car: 96 240sx/92 240sx coupe/94 240sx vert/95 240sx/93 240sx hatch
if your a cheapass
turbosmart manual boost controller
if your on a budget
walbro 255lph fuel pumpebay front mountaltima fansturbosmart manual boost controller (i was running one before i got my greddy)i boost 10lbs of boost daily and 14 at the track
if u got a little dough
walbro 255lphgreddy profect B boost controller (i got one and it holds boost perfect)greddy front mount
if you got a lot of dough
walbro 255lphgreddy profect B boost controller (i got one and it holds boost perfect)greddy front mountaluminum radiatorgood fansgt2871rn62 maf550cc injectorssafcwideband
^thats just a mild tune you could still get extreme.
and i hope your running premium gas cause thats the main thing that will f yo stuff up if your boosting a lot
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
You guys suggest way too much. Chances are if hes on a stock SR hes not gonna have the cash to dump onto upgrading the turbo and such. Also asking what to upgrade to get more power, leave tuning out of the question.
Do the basic first. Intake, Exhaust, Walbro, and Manual Boost Controller @ 10psi. If the car still running good then post back later for more advice.
