Touchdown038 »
https://forums.nicoclub.com/touchdown038-u3917.html
Mon Jun 09, 2003 4:12 pm
Mine's doin the same thing right now, except when I turn on the key, no noise coming from the fuel pump, I'm in the process of replacing that.
But first of all you should find out if you have fuel, spark, and compression. Run some tests and find out what the problem is. Might wanna check your timing too.
