What can be taken off
xckid
Car: 2004 Chevy Blazer ZR2
What can be taken off that restricts the car from more power just post and ill do the search if there is. Kinda bored.
rexhunta
Car: '95 Mitsubishi RVR ( 4G63T and AWD thanks !)
MY10 Forester X LE
xckid wrote: What can be taken off that restricts the car from more power just post and ill do the search if there is. Kinda bored.
roof off, remove seats, run with 10 litres of fuel in the car, put on some 14s, and remove exhaust
xckid
hahahaah yeah so that way ill stand up through the sunroof while i drive. Talk about no more blind spot. but on a serious note what is there
themadscientist
I race naked to improve my power to weight ratio. It also messes with my opponents concentration
When I am trying to get every last shred of advantage I pull out the entire AC system, The whole power steering system and cap the rack, I also gut the interior and just run two front seats. It's loud, it's hot and steering is a bit of a task but it works.
xckid
themadscientist wrote:I race naked to improve my power to weight ratio. It also messes with my opponents concentration
No No i once drove a old As# heavy truck with no power steering or brake booster and to top it off the brakes werent bleed . best day of my life . it took 2 people to turn it. me and another friend. it was fun but i crashed into a building not really a boom crash but hard enough to cause the wall to do the wave.because you really had to pump the brakes. All this happend at school . So really what is there.
themadscientist
then nothing. Basically you have two categories to work with;
Weight, lower the weight by replacing things with lighter parts or removing items altogether
Drag, remove drag on the motor like accesories such as power steering or AC pump.
beyond these things you have to increase power.
240DRFT
take out the a/c...i did cuz during my swap cuz i never use it anyways. and i gut the rear mostly.
tms, i gotta try that racing naked thing
and rex i have no clue how much 10 litres of gas is since we use dont use the same type of measuring lol
Clatch
You can take the resonator of the air intake box, remove the AIV valve system, and remove the clutch dampener box.
xckid
no dont race naked just with the bottom half off. and get tvs in the head rest and blast some p0rn that will distract them.
Zydeco
Car: The poster formerly know as -]sTm[-HeavyHips
1 US gallons = 3.7854118 liters
xckid
What is the aiv valve system and what does it do.
GhostDriver
Car: 1991 Nissan 240SX RMS13
SOme garbage thats supposed to warm up the cat. You can also do without the upper timing guides (KADE).
xckid
what does it look like. most importanly where is it.
Sky240PWR
if you remove the roof, won't that cause drag??
