There is a Q somewhere (I know I have seen it) that simply has a duct cut into the nose.
Imagine this, if you will: The beltbuckle is removed and the notch is filled, such that the nose is now smooth. Then, the nose is cut open and the edges smoothed, so that it's almost like a scoop / funnel / duct.
The best example I can give as to what it looks like is the duct that was put in the bumper of the c5 vette (I think by Lingenfelter) where the license plate would be...
Wish I had a pic to show. It's not classy or pretty, but aggressive-looking, and shows the car means business....
One could even modify that opening to create a serious and DIRECT ram-air type setup, as the majority of the radiator/condenser airflow comes from UNDER the bumper anyway (look at the "ramped" piece behind the lowest "grille" below the bumper....
p.s. Glad to see you guys on some common ground. Props to both.
