JDMaholic »
https://forums.nicoclub.com/jdmaholic-u19677.html
Mon Sep 13, 2004 1:38 pm
First of all I hope you mean 500W not 500A to your sub. Also I would get a cheap handheld multimeter, measure across the battery without the car running, it should be somewhere around 12V give or take, next start the car and once again measure the voltage across the battery the alternator should bring the voltage up to about 14V, if not either your alternator is not charging properly or some other part of your charging system is broken. If you want to check and see if you have a short the easiest way to tell is to measure the current coming from the battery with the car off, and the key in the on position but car not started.( this requires you to remove one of the battery leads and place the meter between the cable and the battery, be carefull) make sure you stereo is off it will draw alot of current. There should be some current draw through the system I'm not sure but probably less than an amp or 2, if there is more than that there is a short somewhere.
