What can a stock clutch handle?
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
I've been searching and haven't come up with anything. I recently picked up a ca and don't want to dump a lot into it, but do want to know if the S15 T28 will over power my clutch at say, 10lbs? I'm sure the 370s can handle it, but I don't know about the stock clutch. I know the answer is to upgrade the clutch, but I really don't have the cash to throw around.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
To answer your question, not much.
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
about 10-15% more torque so roughly 180-190ft lbs at the crank. get a spec stage 1 and call it a day.
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
Really?!? That sucks to hear, sounds like I'll be dumping more into this than I was planning.
Look what I found:
http://www.axidworks.com/180SX%20S13%20 ... %20Organic
Probably a bad idea, lol
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
If you can afford a new clutch I'd put one in, if not, just leave it. The worst that can happen is it starts to slip and you have to buy a new one anyway lol
s13drifter88
the clutch wont handle much more than what the stock turbo can do on 10 or 12psi. Wastegate on the s15 t28 is 10psi. the ca turbo is smaller than an sr t25 and we all know the s15 t28 is even bigger. the s15 t28 will put you around 200whp and close to 200wtq at 10psi so the clutch will basically hate you. the stock 370s will handle it just fine. my best friend has an sr for his dd and it does just fine on 10psi, both of which have 370s. if you have the money for a t28 upgrade spen the extra $200 or so just to get a good stg1 clutch. most of them will hold 40-50% more torque and should hold that turbo just fine
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
The engine came with the turbo. If I get a clutch I'm gonna want to up the boost. I wonder how far I can go on everything else?
Noxy
Car: 1993 Nissan 240SX
1992 NX2000
2004 Sentra Spec V
Hey mmm240 I saw you were looking for a PS pulley and didn't want to jack yohnp's thread. I have a set of ralco pulleys that I don't want. $20+ shipping if your interested email me at [email protected]
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
E-mailed you
s13drifter88
with the stock maf about 12psi which is about how far u an safely push it with the stock fuel system. anymore and larger injectors and bigger maf will be required. 550's, n60 maf and a Jim Wolf rom tune should get u close to 300ish numbers with the s15 t28
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
That's good to hear. I'll probably be happy with that for a while. Forgot to add, the car has a 255 walbro and I have evo injectors that I've been trying to sell for some time, I'll drop them in if I feel the need for more power.
s13drifter88
the evo's should be 450cc, they should be plenty for the s15 t28
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
Got em' cleaned and tested already, flowed around 600. Asking 250, maybe I'm asking too much?
s13drifter88
hell if they flow 600 id keep them. with a $400 Jim Wolf flash and a $50 n60 maf you could be making 300ish whp
