What cams to go with on my set-up??
Solow240sx
Car: sr20 powered 91 240sx
Ok guys just wandering what cams u think i should go with i'd like to go with brian crower 264's or 272's, Anyways heres the set-up i will be running and im looking for around 450-500rwhp??...
red top SR20DET CP Forged 86.5mm-8.5x1 .20 over pistons eagle forged H beam rods with arp bolts Acl race rod and main bearingsARP main studsWet Magged & polished crankBalanced rotating assemblyApexi 1.5mm headgasketARP Headstudspeakboost top mount manifold, downpipe, and t3/to4e turbo710cc injectorsGreddy rocker arm stoppersBrian Crower Valve springs and titanuim retainersGreddy intake manifoldJGY Lightweight polished pulley kitZ32/300zx MAFS Greddy front mount intercoolerApexi power intake kit
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
I'd go with tomie 270 procams. Stay away from BC cams. The tomie and HKS are worth the extra $100 IMO.
Kalypso
nice setup,
post pics when its done
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Tomei, HKS, or JUN.
Solow240sx
Whys everyone saying to stay away from brian crower??
kentuckyslider
Inconsistant machine work, cam timing issues, you get what you pay for and IMO the Tomie or HKS are worth the extra money. Some people have had good results with BC cams but many have not. If I was putting the kind of money you are into a SR I would spend the extra $100 for piece of mind. P2M cam off $50 on their tomies for me because I told them MYSr20.com had them for $440. Tomie 270's if I were you. The HKS 272's only have 11.5mm of lift compared to 12.5mm in the Tomies.
Solow240sx
Ic, im probably going to end up getting the tomie procam 270's, does anyone no if anything else has to be done to run them other then valve springs & retainers?? And how will they idle...
Solow240sx
Would it be worth running something like a 264,272 combination to bring in the power alittle earlier or will i loose top end power??
jr_ss
Car: 95' S14
One, you should search, this has been covered a thousand times, not to mention there's a post about this like 8 posts down.
There is a cam fact-thread and pretty much tells you what cams to run with what turbo/mods.
272 is going to be way too aggressive with your setup depending on turbo ex housing size. I'm not a huge fan of staggered setups anyways.
kentuckyslider
The tomie 270's will be all top end and for drag racing with your setup. I went with the 260's and I feel they are the best all around for my 2871 .64 ar.
vanquish2
Car: 92 240sx
They are correct....we used some bc cams until we found out that they were anywhere from 3-20 degrees off of 0 from the factory! BTW 20 degrees is 1 tooth on the chain!!!
Spend the extra money
DrifterProdigy85
270's powerband is pretty much from 5000-8500rpm. You really dont need the 270's unless your going GT30R or larger. I always match the Duration with the Spool of the turbo and higher the Lift should give more power.
