What camber issues will I face with the specs on these springs
s13pignose
Car: S14
Springs I'm looking at have the following specs:
Drops the front -25mm or -0.98 inches, and the rear -20mm or -0.79 inches
Spring Rate: Front- 2.9 Kg/mm Rear- 2.7 Kg/mm
Plan on runnin 17's on my s14 with these. How will camber be affected, and how much will gap do you think will be left. Don't wanna slam it cause I think it sits low know, and I have no need for drift or auto cross.
Also what are good inexpensive struts to run with these?
Thanks for any input
cdlong
Car: '95 240sx
probably about 1.3 deg front and 1.8 or so in back. not bad if you get it aligned to fix the toe.
you'll still have a decent gap.
KYB GR-2s or koni blues i think are the cheap ones.
