I have a set of the 4 piston calipers from the 300ZX Turbo along with a set of the standard 30mm rotors.
I have another set of calipers that look the same except the mounting earsseem to be a bit longer then the standard calipers almost looks like they will fit a bit larger rotor.
The 3rd set again is the same except the mounting ears are way longer then the stock calipers and look like they could take a 2" bigger rotor.What are these from and more importantly what rotors will fit them? Will the 350z Track rotors work?
Thx,Timhttp://
www.timmymegenbier
