Dori Dori »
https://forums.nicoclub.com/dori-dori-u2872.html
Tue Jun 24, 2003 8:04 am
Definately the T/C rods first. The stock ones really suck. One thing worth noting about these though, is that they can cause your front LCA's to crack. You can read about this on freshalloy and maybe the faq here (never checked here). If you want a more reliable replacement, you can get all new, adjustable t/c rods w/ spherical bushings instead. They allow play that prevents the stress to the LCA. I got mine through SPLparts.com...they are $140 now; that's a good amount less than any other.
Next do the control arms...uppers and lowers. Spring for the eccentric ones first, no reason to go back and do them later (they are the rear upper control arm bushings, so you wouldn't buy the non-eccentric upper control arm bushings in this case).
The D bar bushings are probably the least important. You should consider the endlink bushings though, they'll make a bigger improvement IMHO. Also, make sure your car has a sway bar (and know which one) before you order any of those (I could be mistaken, but I believe some s13 240's came with no swaybars).
I believe you can also order bushings (eccentric and non) for the rear foward link (pdm calls it the Upper Front Toe Link Control arm). They sell refurbished arms w/ the bushings already pressed, so I don't see why not. If you write them, they will be able to tell you (they usually reply fast...maybe I'll write them and post the info/part numbers here).
Lastly, the rear subframe collars (the pineapple slice looking things) would be good to get as well. You don't need to press fit these though, they just slide between the stock subframe bushings and preload them, so install is cake.
