Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Tue Feb 13, 2007 2:07 pm
If you intend to lower the car, you need adjustable upper links. The ones for the 300zx will work. They are solid just like the adjustable tension rods. With these two adjustable links, you should be able to lower the suspension and keep the geomerty relatively good. The other issue, is the placement of the steering rack. You really need to raise the rack, to keep the steering links in a nice horizontal plane. Bump steer is not fun, expecially on a track. Of course, you will not really be running the Q on a track, if you are installing 20" rims.
The other thing to consider is a rear adjustable control arm, so you can keep the rear camber close to spec when you lower the vehicle.
The upper link is responsible for 90% of the front end noise, 9% is caused by the strut itself, .9 % is the brakes. All the rest of the front end is responsible for the other.1%
