What breaks in a rear fender bender?
AdultingWell
Car: 2017.5 Rogue SL
Hi, earlier today my wife backed into someone and rear bumper took a light beating from ~45 degree angle. Metal is untouched. :gapteeth:
It looks to be 4+ hour job to remove the bumper and I want to get all of the parts ahead of time.
Any suggestions as to what would need to be replaced?
Thanks!
AdultingWell
:gotme bump
You're not going to know until you open it up.
Typically, there's a chunk of styrofoam behind it. You may have gotten lucky and there's no damage behind the urethane cover.
p.s. It's not nice to blame it on your wife. ;)
macgiver
Hitman is right ,gotta get in there- cause it would be a bad move to buy anything in anticipation , too wide range of damage,and try to return those ? The "energy absorber" on frame is plastic and on top of that, shaped styrofoam that "fills" under bumper skin could get deformed.
Tip - A-zone's have a black body epoxy that's flexible , great for plastic "skin" bumper tears ,I've used the expensive 3m (was tan) , gotta re-paint ya know.
Also the styrofoam , if gotten "deformed" - you can try that Home depot Low expanding foam in a can to kinda fill-in like bodywork so you won't have "hollows" beneath the bumper skin. Ya just trim it down with a knife when fully cured and sculpt a "best fit " for yourself :naughty:
Return to “Rogue Forum”
