bcar240 »
https://forums.nicoclub.com/bcar240-u13477.html
Tue Oct 19, 2004 9:30 am
yeah, it is a pretty simple install. There are a few sets of intructions floating around on here but good luck with the seach. The only that that held me back was the tubes on the old filter were on there very tight. Even after I removed the clamps, they didn't move at all. I finally was able to twist them back and forth and they came off. Also make sure you either remove the fuse and relieve the pressure or clamp the lines so you don't have gas come running out when you remove the tubes.
