What brand of LED headlight bulbs are you using?
xXMirageXx
Car: 91 240sx coupe
Hi guys just wanted to see what options are there that have been tested personally and can be recommended for every day use and have a good life span. Im currently running Lasfit Led bulbs in my 2016 Sentra SE. I used to have the opt7 kit but it wasn't as good as it was described and we all know that usually the more it cost the better it should be but after having one of the opt7 bulb fail me after a year and had them replaced i decided to give another brand a try. I went on amazon and looked for something that wouldn't put a hole in my wallet and decided to risk it on the Lasfit brand which where on sale for 50 bucks it looked good to me specially since it doesn't include the extra extension and was half the price of the opt7 and so far i like them and i can see better at night than the opt7. So i want to know what lights you guys run and how good do they perform? The one i currently have are plug and play to the original harness so no wiring needed did you have to wire your own? did you need extra adapters? got any pics or videos of how they look on your car? Let me know :) if you have any questions on the opt7 or the Lasfit kits i got feel free to ask and ill answer to the best of my ability :).
pictures of my sentra with Lasfit led kits for low beam and fog lights.
PapaSmurf2k3
Site Admin
This thread is relevant to my interests. Those lights you've got look good.
I really should upgrade the lighting in my 240. Last time I checked though, LED housings were $300+, which isn't gonna fly for me.
BusyBadger
Car: '92 Nissan 240SX
'05 Nissan 350Z
'13 Nissan Juke
I'm not using any right now, but I've always loved what Clear Corners puts out. I've toyed with the idea if having a set done for my Z if I end up keeping it...but they're about as far from inexpensive as you can get.
float_6969
I started out with Plasmaglow, but the lifespan wasn't acceptable, so I switched to http://www.ledheadlightspro.com/. It's only been a year, so time will tell, but so far they've been good. I was also able to get them in a much higher wattage than what I did from Plasmaglow.
xXMirageXx
Car: 91 240sx coupe
PapaSmurf2k3 wrote:This thread is relevant to my interests. Those lights you've got look good.
why not go for the Hella housing?
https://www.amazon.com/Rectangular-Halo ... +headlight
im planning to do this to my 240sx as well i still have the flip up so dont know if you got the silvia conversion but my car isnt running yet need another motor T-T then ill change the seal beams to the removable bulb housings :).
xXMirageXx
Car: 91 240sx coupe
BusyBadger wrote:I'm not using any right now, but I've always loved what Clear Corners puts out. I've toyed with the idea if having a set done for my Z if I end up keeping it...but they're about as far from inexpensive as you can get.
Dam they would look really nice Hope you keep the Z tho :D
xXMirageXx
Car: 91 240sx coupe
float_6969 wrote:I started out with Plasmaglow, but the lifespan wasn't acceptable, so I switched to http://www.ledheadlightspro.com/. It's only been a year, so time will tell, but so far they've been good. I was also able to get them in a much higher wattage than what I did from Plasmaglow.
cool thanks for the link its good too know theres options out there for me in case i decide to change my current set up i have the Lasfit 36w per bulb 4000 lumens per bulb 6k color. Which ones did you get from ledhedlightpro and hows the visibility at night? Thanks
float_6969
They were for my Mazdaspeed Protégé. I got the H4's (high/low), white, 45W (per bulb)
xXMirageXx
Car: 91 240sx coupe
float_6969 wrote:They were for my Mazdaspeed Protégé. I got the H4's (high/low), white, 45W (per bulb)
cool the aftermarket housings for the 240sx flip ups use h4 bulbs so i might give them a shot thanks :D :bigthumb:
PapaSmurf2k3
Site Admin
xXMirageXx wrote: why not go for the Hella housing?
I had thought about it, but a lot of the H4 LED bulbs have big heat exchangers off the back of them that I fear would catch on something as the headlight flips up and down.
If you try it out, do a write up and let us know how it works.
xXMirageXx
Car: 91 240sx coupe
Sounds good ill get that done as soon as i get the housings and bulbs currently my car dosnt run due to needing a good engine mine currently giving me infinite problems with questions i cant find answers too lol but electrical works and i should be able to test the flip function and report back with what i found video sounds good?
PapaSmurf2k3
Site Admin
:bigthumb:
xXMirageXx
Car: 91 240sx coupe
Sorry guys for the delay work picked up and been busy with life as well but here's the video i promised. I was able to get in contact with Lasfit Auto Led Lighting and they hooked me up with a sample kit to test in my 240sx if i provided a installation video. So here you guys go if you all ready know how to swap your lights you can just simply skip to 18:50 to see that as long as we properly mount/ position the led and factory harness we wont have to worry about it getting caught in the retraction when opening and closing. For those who are new to these vehicles or never replaced their stocked sealed beams i recommend watching the whole video which i showed some of the problems you can run into and how to fix it.
If you have any questions feel free to let me know :D. Please like and subscribe to their channels it will help me get my interior lighting swapped to LED if I can get them to reach 100 youtube subscribers thanks!
Hella housings total cost was about 130 shipped to me from Amazon
LED kit used in video can be found here:
Our Harness plug is H4
Amazon Lasfit LS H4 cheaper than website:
https://www.amazon.com/LASFIT-Headlight ... t+h4&psc=1
LASFIT.com:
https://www.lasfit.com/products/lasfit- ... 00lm-6000k
PapaSmurf2k3
Site Admin
This looks great. I'll have to watch the whole thing when I get the time. Thanks!
xXMirageXx
Car: 91 240sx coupe
PapaSmurf2k3 wrote:
Tue Aug 01, 2017 11:11 am
No problem thanks if any one have any questions feel free to let me know and ill answer to the best of my ability. I been chatting with LASFIT and im trying to see if i can get us a discount code so if any one else want to try them out we can get them for a good price.
Ill keep posting as i get new updates on this. Normally i dont post here a lot so if im doing something wrong please let me know also should i need to make another post for the code if i can get a deal with the LED company? or just keep posting on here let me know thanks :)
PapaSmurf2k3
Site Admin
I just watched the video in its entirety. VERY thorough. Thanks for doing a great job!
5,000 lumens per bulb is freaking nuts.
xXMirageXx
Car: 91 240sx coupe
Thanks :). Also an update for anyone interested in trying out these lights LASFIT will be providing me a Amazon 50% discount code for their Lasfit LA Series LED kits if anyone is interested let me know and ill post the code :)
PapaSmurf2k3
Site Admin
I couldn't find the LA series in an H4 bulb, but it looks like their driver is internal, yes?
xXMirageXx
Car: 91 240sx coupe
yeah that is correct everything is in the unit itself the ones i tested since they use more power to produce more light they made it external which is the little black box attached to the cable. Here this is the link for the LA series H4.
https://www.amazon.com/LASFIT-Headlight ... =lasfit+H4
pretty much when you are ready to order let me know or join their LASFIT fb oage https://www.facebook.com/lasfitautolighting and send them a screen shot of your amazon purchase and let them know you are from Nicoclub forum and Mirage sent you to get the 50% discount (pretty much they way they explained it to me was if any of the forum members bought a LA series light from their amazon branches and left a good review they will refund them half of the totaled paid and still get the 1 year warranty if provided a screen shot of their review on amazon)
PapaSmurf2k3
Site Admin
That's pretty awesome man. Thanks!
xXMirageXx
Car: 91 240sx coupe
SO here it is guys they gave me a 20% discount code for any of their LASFIT lights on Amazon!!
20% OFF --3NNBQDON (use it while supplies last)
Also i was told that for every one who purchases on Amazon and leave a qualifying good review, meaning actually give honest feedback and details of how they can improve or what can be done better with their lights or any suggestions for any kind of product you would like to see them sell they will receive a free gift.
If anyone is into doing video reviews this is for you! If you like to make tech videos or how to videos, Make a video installation and give a review of how easy, difficult installation is. How the quality of their units feels, what you think about them etc. Post it on youtube and paste your link onto their Facebook page and get a chance to get a free set of lights as a gift. (which series exactly I don't know but they're free so cant complain right? XD)
Well hope this helps anyone looking to get LED lights for their vehicles :D
This is My youtube channel if anyone wants to follow :) I like to fix My 240sx problems and upload fixes for anyone else who might be experiencing the same problems. Also im currently restoring my 240sx as well so anything i find is worth showing to the community ill be posting on my channel as well :)
https://www.youtube.com/channel/UCDK5xH ... kRVZz0WwXg
